New System Options
PaulS63
Why not just use the existing Bose amp? Easiest solution.
byrds6
byrds6
FL
I plan on leaving the Bose amp in place. I just meant the actual output of the stock system vs aftermarket. I did notice too that the sensitivity of the Kenwood headunits for the FM radio exceed the Pioneers. Its so hard to decide what to do lol. I surely do not want a laggy/buggy unit nor one that sounds worse than stock. Almost any nav should be better as there have been many times the stock nav has sent me to the wrong address or did not tell me the absolute best/fastest route to take.
mr tahoe
I went with android double din and ill make it really easy after using my deck i wouldnt trade it with any name brand i just love, having google maps and wifi in your own car radio is just frkn awesome
byrds6
byrds6
FL
Honestly I probably wouldnt use Google maps from my phone. I do not think I like the idea of my phone having to be plugged in all the time. However I do know that both the Pioneer and Kenwood have built in maps as well. I think the Kenwood has Garmin and Here and the Pioneer only has Here.
PaulS63
Radio sensitivity of the Kenwood is awesome. Bose doesn't provide any specs for the amp, but it's way loud, even with the 4 ohm aftermarket speakers. I'm using a Maestro rr with gm5+ and it's very easy to set up. Only snag with aftermarket head unit is the depth. Have to remove plastic piece behind to make room for it. Also the metra dash kit is too wide for the bezel, have to sand off 1/16 each side.
byrds6
byrds6
FL
Whenever I figure out what unit I want I'll probably just have it installed. That way if something happens they are responsible for fixing it. I meant output of the actual head unit. The amp will increase whatever it's given to the max of its ability. Of course if it's given less there will be less output. I do think I'm leaning more to the Kenwood though. I just don't want a paperweight. Lol. Is Kenwood owned by jvc now?
PaulS63
I believe the bose system head unit output is line level.
byrds6
byrds6
FL
Both woukd still have an output wattage correct?
jhax01
This is not for everybody of course, but there's always the tablet approach using the stock radio, etc. I've done this in my last couple vehicles and it works great for navigation, music, etc. Just depends if you're bothered by the appearance I suppose. My setup is reasonably clean and when it's time to trade/sell the Burb, I can get it back to stock in a few minutes. Not to mention that to me, at least, having the navigation screen higher up and more in your line of sight is really helpful. The iPad has its own SIM so it doesn't rely on connecting to another device for nav/music streaming.
tswelsh
