New tire question- normal amount of weights?
NathanJax
Vacation Nathan
Administrator
Jax, Fl
Hell nah
They should have rotated the tire around on the rim to see if it would balance better.
I would go back, have them remove the weights and the tire, and balance just the rim... If the rim balances fine, or close to fine, they need to give you a new tire. That is 100% not acceptable.
Tk59194
Tk59194
Thats what I thought. Three of the 4 tires have 10 or more weights on them. 1 of them has 1. The one in the photo has 19 of them.
Kpwweb
I would ask for the road force numbers. 40-45lbs is the max (depending). Road force is (probably) more important than actual balance. The shop I took mine to also discussed static balance and dynamic balance... Static balance was taken care of by clip-on weights inside the wheel. Dynamic was with the stick-on you see through the spoke. See if they can give you a road-force balance.
CMoore711
I have never in my life had that many weights put on any OEM stock and/or aftermarket rim to balance a wheel.
New tires? What brand? More info please. If they’re cheap Chinese tires or rims it’s possible. Sometimes the tire is so out of round that it’s nearly impossible to balance.
Tk59194
Tk59194
Yes, these are brand spanking new Nitto terra Grappler G2 tires. The truck is a 2018. I have just over 13000 miles on the truck. I am fully aware that AT tires sometimes require more weights to balance than an all season tire, but I thought this was excessive. Also, they were road force balanced. Discount tire is who sold me the tires and balanced. For those of you with AT tires, what is your experience? 20 1/4 ounce weights is only 5 ounces, so it's not like that's way out of tolerance or anything, it just looks like shit imho.
Scrivers
