New to me 07 Tahoe LS with 5.3l few issues
Geauxturbo
Service engine light popped on. Its the gas cap code. The evap can solenoid was replaced just before purchase. I'll try a gas gap. Reset the codes or will it go off quickly if thats the fix?
Tire monitors need replacing. Already learned em good twice. Guessing batteries have reached their end. Whats a good brand to get?
There is an annoying rattle/squeek under the steering column coming from the kick panel. Anyone have this and fix it?
Other than that, all is good :)
G
Geauxturbo
Figured out the rattle/squeek. There is a metal plate attached to the kick pannel (knee panel or whatever you call it). Its held on with molded plastic rivets. They werent tight. So, I superglued spacers made from faux cork between the metal and plastic. No more squeek rattle.
hiles
Good work! Hope you'll like the car, i'm super happy with mine.
Administrator
What do you mean "batteries"? There are no batteries for those sensors. I'd just order new ones from the dealership but would have them try to set them for you real quick(should be free) before ordering. The 07's can be a PITA to "re-learn" and the dealership has a tool.
G
Geauxturbo
Pretty sure there are batteries molded into the sensor. How else would they transmit a signal? The process for retraining wasnt difficult, it just keeps coming back as a tire monitor malfunction later down the highway.
@superchargedss. Thanks for the link!
G
Geauxturbo
My luck. Not a bad gas cap or evap canister/solenoid. Iys the tank pressure sensor. Gotta drop the tank and I let the dealership do that one. $550 to get that blazing orange light to go off. But can't get a brake tag with it on, so dropped the cheddar this morning.
Belt tensioner was weak. Replaced that and the AC belt
Adventure Ed (what the kids named the Tahoe) is going to back to new by 3:00 PM.
Garage2010
