jdwood1111
- Joined
- Jun 16, 2022
- Posts
- 116
- Reaction score
- 144
Background:
Hi everyone. My name is Jordan and have been a honda and acura guy most of my life but I recently purchased really clean 2011 silver Yukon XL Denali with 92k miles on it. One scratch on the rear passenger bumper and not another single scratch or dent anywhere! Everything on the interior works perfectly without issues and drives great! I bought it from a dealer who provided a 60day 2k mile warranty and after I identifying a trans cooler line leak and my mechanic finding a oil cooler line leak, they actually took the truck back and had both fixed no questions asked! This impressed me since it was not a extremely large dealer. This is a second vehicle for my family of 6 (4 little ones all 7 and under and no twins). My wife drives a 2011 odyssey and I have a work car.
Truck History:
The carfax shows only one large service record showing front ball joints were replaced, plugs and wires, brake fluid exchange, new tires balanced and alignment. I have identified the rear rotors appear to be new and everything else seems to be in line. So far I have installed Range AFM device per info on this forum, an Airaid intake tube, AEM dry filter and cleaned the throttle body during that installation. I also just flushed the power steering fluid via the dry turning of the wheel method with a hose which went well. I currently have 2qts of Dexron 6 ATF for the transfer case and 5qts of AC Delco Syn 75w90 handy for the front and rear diff to do as soon as I get a free day. So my only questions and concerns are now the following:
-Any other maintenance items I should take a look at? I did see the front brake pads will need replacement soon and the lower shock bushings are quite warn but the truck rides fine for now. I will most likely replaced the brakes with centric as that has been my go to for a while now.
-Transmission was shifting hard from 2 down to 1 but is a little smoother with the Range device which i attribute to the 4cyc to 8cyc timing. However, just yesterday it slipped slightly when trying to accelerate from i think 3 to 2, may have been 1 to 2. It was quite hot and the AC was on as well. I was planning on doing the trans service and filter myself as i am pretty handy but this may be a little more then i want to do in my driveway and got a quote for $285 from a reputable AAMCO place to drop the pan and do the fluid and filter. Trans temp always are quite low from what I have looked at.
-Unfortunately, it seems the oil cooler lines did not completely stop a leak as I still have a small amount of oil accumulating at the known rear engine and transmission. I looked inside the bell housing cover and it appeared to be mostly dry so hopefully not the rear main seal. I cannot see if its the intake cover or the oil pressure unit but was thinking of trying to replace the sensor JIC. My pressure is mostly above 40 when starting and driving around except at hot idle, it drops to around 28-30 or so which I believe is normal? I did try to tighten a couple of the oil pan gasket bolts and the bell housing bolts but have not checked it again since. It has not left anything on the ground at all only a little wet here and there.
Otherwise, I hope this truck last me quite awhile as I really enjoy the 6.2L motor and AWD!
Thank you,
Jordan
Truck History:
Thank you,
Jordan
