New to the forum & have major problems...Help!
Star
California
I am new to the forum and came seeking help, my baby has issues.
I have a 2003 Yukon SLT 4x4 with a 4" Superlift and 33" Dick Cepeks.
The problem: When i accelerate from a stop it sways very bad, more like jerks left & right. It also jerks hard back and forth when I hit a bump. The ABS grabs when I'm braking going over small bumps and my service stability keeps turning on, but goes away when I turn the engine off and re-start it. It's very unstable and am being told I should not drive it.
My problems started about a year ago with a clunk in the front end. We've been working on it non-stop ever since. Everytime we fix something a new symptom appears. I will spare all the details leading up to my current situation but just tell you that we've changed the following:
Sway bar bushings and end-links
Upper ball joints
wheel bearings
Tie rod ends
pitman arm
Also have had it aligned several times.
One shop said my rear dif posi-lock governor was stuck and it was causing the problem. They also diagnosed the upper ball joint problem, which we fixed.
Chase Chevrolet says there's nothing wrong with my front-end but they wanted to open my rear-dif and look at it. The day after taking it from Chase, big o tires said my pitman arm had play so we changed it.
I was told today after the new pitman arm was installed that they've never seen anything like this before. These mechanics, who are my husbands friends and he trusts, say we may just need to keep throwing parts at it, eventually we'll find it. They say it may not even be the front end, it may be in the rear-end causing the front-end to sway. But after further inspection they said the control arms look like they're moving, which my husband observed. Those will be changed tomorrow.
So now I have 2 places saying rear dif and another that says it could be rear-end. Yet we keep changing front-end components!! If the new control arms don't work I will take it to a rear-end shop and have it popped open and looked at.
Has anyone out there experienced this problem? Please, help!!! I love my truck but I'm about to drive it off a bridge!! :emotions122:
BOSS
The People's A D M I N
Dallas
Welcome to the forum! We don't have many ladies so BIG WELCOME!
Does it sway in 4x4?
BOSS
BOSS
Dallas
What codes are you pulling?
Does it still happen when you disable traction control and stabilitrac (I assume your has both)? (Hold button for 5+ seconds)
B
cam3439
Is it more of a wobble? Does this happen all the time or only during acceleration? I've heard of the "Death Wobble," and I would look at the provided link if I were you...
http://jeep.off-road.com/jeep/article/articleDetail.jsp?id=261532
Did this happen after the lift (or soon after) or have you had the lift for a while? Did you get some extended end-links? Is the steering column itself fine (is it all tightened down)? While parked, do you have play in the steering wheel?
I'm also a member of other forums that might be helpful.
http://z71tahoe-suburban.com/ or http://chevroletforum.com/forum/
Star
Star
California
B
Chase didn't pull any codes.
It does have both, My husband is going to disable it right now and I'll get back to you.
---------- Post added at 09:06 PM ---------- Previous post was at 08:40 PM ----------
That link didn't work but I pulled up some videos and that's not really what it's doing; the whole front end jerks to the right then back to the left but it doesn't wobble like that.
I didn't mention that when i accelerate my front tires pull in and squeal like they're breaking traction.
The truck was lifted when I bought it and had none of these problems the first year I owned it. There is no play in my steering wheel when I'm parked. I do have a noise coming from my column but, from research I've done about that I do not think it's related.
---------- Post added at 09:06 PM ---------- Previous post was at 09:06 PM ----------
B
Yes it still does it with it turned off.
BOSS
Dallas
Damn...sounds like a tough one.
Tonight's not a busy night here, hopefully since I copied this into the 99 section some of those guys can help.
B
BOSS
Dallas
Detail pics would definitely help if you can take some in good light
B
BOSS
Dallas
WHat does it do in reverse out of curiousity?
B
etreanor
