new wheels & tires
onelovechicago
Just got these put on this past weekend, reproductions esky 22's with Nitto 420s 305/40r22. Just wanted to share..
Denali0229
FL
Looks really good. Def an upgrade over stock wheels.
onelovechicago
onelovechicago
Looks good! Thinking I want to go with the Marinellos more each day!
These arent Marinellos, i wish they were. These are from factoryreproductions.com. got them from discount tire for 2190$ out the door with tires and sensors.
Here's a question, was told that i dont need a wheel alignment since there pretty much the same height. true?
NathanJax
Vacation Nathan
Administrator
Jax, Fl
Here's a question, was told that i don't need a wheel alignment since there pretty much the same height. true?
Just swapping rims and tires doesn't change your alignment. If you've already had a proper/correct alignment, it should not change alignment until something in the suspension wears out or is damaged. Alignment doesn't change. The only thing that changes it is wear or damage.
Jeremytahoe
