Newbe here, radiator cooling fans not running on my 2005 yukon denali
trikeman
Checked all (3) electrical relays, changed the temperature sensor, fans will run if I remove plug from temp. sensor, shut down as soon as I plug sensor back in. What is the relay under pass. headlight and behind bumper cover? Need help please reply. Thanks
SLCHOE
ASE Master Certified + (L1)
Midvale, Utah
Do they come on if you turn your A/C on?
You replaced the Engine Coolant Temperature switch?
tswelsh
