Newbie needs help!!!!
racingrisa
Just picked up a 04 with 24's on it and a 2/4 lowering kit mcgaughys...having major rubbing issues really like the look but drive a ton of miles and these tires are getting eat up not sure how the heck they were driving it before I got it. Anyways what are my best options.....again I like the look and would prefer to keep the wheels I was looking at ride tech shockwaves anyone have any imput on them?? The inner fenders are intact still and I have been told they have to be clearanced to run the 24's any advice would be awesome!
Thanks
R
racingrisa
295 / 35/ 24 not sure of offset and Thank you for the welcome!
---------- Post added at 08:14 PM ---------- Previous post was at 08:08 PM ----------
offset measurement from the back safety bead to the mounting surface of the rim is 6 inches
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
If your tires are unevenly worn the previous owner may not have had the alignment done after lowering it. The size you are running sounds common so you should be good there, and offset is measured in mm (which I was referring to at least is typically ~30, + or -). If a re-alignment wasn't performed that could be the problem. Unfortunately new tires may have to be factored into your solution...
Donnie Yukonie
Yates Caretaker
welcome to the forum . and shall i recomend new tires b4 alignment once a tire starts wearing a certain way it tends to remain wearing like that
R
racingrisa
hmmm ok tires are like new they are rubbing on inside fender and inside lip is cutting the one tire some...there are visible rub marks on the upper inner fender well
---------- Post added at 08:28 PM ---------- Previous post was at 08:25 PM ----------
thank you donyukon the tires are or were new till i got it drove it 4 days and tires are getting cut up primarily drivers side so thats why i was looking into the ridetech shockwaves
R
racingrisa
Ride Tech Shocks????
Anyone running ride tech shockwaves in the front? Looking for feedback good or bad before I shell out the money for them anyone????? Appreciate the help.
Thanks
05whitenali
The rubbing on the inner fenders wont really hurt much but as far as the tire rubbing the inside lip of the fender and cutting in to the tire that's not a good thing. I personally would try rolling the inside lip of the fenders or trying to tighten the torsion bolt a little to lift the front up just a tad to were it wont hit the fender lip any more. It sounds like if you are rubbing the fender lip with that size tire then you are a bit lower then 2 inches in the front. Your offset on the wheels might not be the best either cause I never had any rubbing issues with that size tire and I was quite a bit lower then 2 inches...it only rubbed the inner fender wells, not the fender.
Donnie Yukonie
Yates Caretaker
Is the vehicle 4x4 if so you could crank your torsion bars a tad
Sent from my DROID4 using Tapatalk 2
Maxpower_454
