Newbie
S0_chi
Chicago
Hows going guys I just bought a 2000 GMC Yukon XL I'll need alot of help getting back up to par.... is this the place to be?
S0_chi
S0_chi
Chicago
Rangel so far
Rear differential has a leak (probably just need a new seal)
Gas hand is malfunctioning (I think its the fuel sensor that attached to the pump)
Need a A/C control module
ABS light and brake light illuminated
Vibrations when traveling over 45 mph
4x4 four indicator flashes on once pressed
Driver door hinge and bushings need to be replaced
02yukxl
Huntertown indiana
This is a good place to be. Let us know what the first project you're going to tackle will be.
Rangel
Great State of Texas
Abs and parking brake should be a linked to a faulty wheel speed sensor. Mine is doing it too.
I've got new wheel bearings in my cart at Rock auto. Just waiting for the "boss" to release funds. Lol
Rangel
Not sure. Possible. I stay away from 4x4 like the plague. Just more crap to malfunction and oil to change.
02yukxl
Huntertown indiana
Door bushings are quite easy as well. Door is plug and play. All connections by the drivers left kick panel. Disconnect the harnesses. Unbolt each bolt on the hinges and the door pulls up and can be set aside. The pins are held on by C-clips. Replace and reverse steps. I've done it on my old Tahoe 3 times. These doors are heavy for the design with the pins. I'll be doing mine soon. I have the pins already in the toolbox. Has a slight lean. Will do a thread of the process.
S0_chi
S0_chi
Chicago
Thanks guys
---------- Post added at 12:53 AM ---------- Previous post was at 12:48 AM ----------
02yukxl yes it feels like it never engages the indicator only flashes
humphr90
