NNBS Kelderman air suspension kit
Status
Not open for further replies.
Goodinblack
I Like Tacos
Dirty South
I was really considering just doing the REAR in airbags and the front on drop struts.
so 2 bags in the back and the brackets, one tank and compressor
NathanJax
Vacation Nathan
Administrator
Jax, Fl
for that, your gonna need the entire kit, minus the front bags and hosing. yo could get rid of 1 tank if you wanted to, but do THIS setup in just the rear is only gonna save you $500 or so...
yates ™
Resident Apple hater
Iowa
In order to do the rear system only you could eliminate a tank and still use the brackets to hold the one tank in place. The problem is the controls (Touch pad system, valves, sensors) are only set up for a 4 corner system and will not work for a 2 corner system. The other thing to think about when only doing the rear is that ride height is around 2" lower then stock so if you lower the front say 2" you will still sit 2" higher in the rear.
I am not going to offer different solutions in this thread because it is Chads for sale thread.
Blazed
Accepting Donations
So at comfortable ride height this kit is 2" lower than stock on all four corners?
sick1166
can this unit be used on a non air tahoe ,I looked at their website and it seem to say for autoride only? sorry I dont know much about this system but very interested in adding it to the hoe 2007 tahoe non auto ride is your kit all i need or something else? thanks, andy
yates ™
Iowa
Yes.
It will work for either and Chad has what you need!
yates ™
Iowa
This (iwaslowr's) kit has everything including the ride height sensors.
Shit sorry I get the 2 threads confused. I will edit my post and you edit the quote. :Handshake:
iwaslowr
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
If you do not have OEM autoride height sensors you'll need the one's that I'm including in this sale. :Handshake:
Yes.
Sensor kit has already been purchased, and is included. :Handshake:
No problem Yates. :Handshake:
Blazed
Accepting Donations
So at comfortable ride height it's still super raked?
Status
tdeaton3
