NNBS: where to get replacement gears for power seat / stripped teeth
04ctd
Charleston SC
my driver side seat does not work in the recline mode,
I can hear the motor running, then it overheats, and stops running.
took the bottom of the seat apart, and the gear was busted up, and the broken parts had jammed in the teeth.
the plastic gear is pressed on to the screw shaft, so i took the whole shaft & lever set up out
how/what do I get to replace it?
will dealer have in it stock?
pics to follow, just need to find the part to fix it
welp, the dealer had the part...oh, wait, still HAS the part, because I did not buy it.
you have to buy the whole seat bottom assembly from the dealer.
I am off to ebay, somebody has to have one that is broke in a different place than mine, and i will buy that, and get what i need off it.
07-08 $449.60 $266.52
Seat track - Bucket seat Driver side W/o power lumbar - Bucket seat Driver side W/o power lumbar
you can find on here:, but the dealer has a newer picture:
http://www.gmpartsdirect.com/catalog/frameset.cfm
SWSS
Smashville
same issue here. feels like i am driving an 18-wheeler! Did you ever find any help? gmpartsdirect.com has them for $378 now. checking pick a part but...
Ilikemtb999
Denver
Gruven parts makes replacement gears out of brass. A little work to put in but far cheaper.
SWSS
Smashville
Sweet! Looks nice. Well, I will buy a set of the brass, replace the broken ones. Put it back in and sell the "new" one!
shreksbrother
Auburn Hills, MI
I've got a driver seat I'm literally going to throw away due to gun wear (PPV seat). It's power. I'm happy to pull whatever you need... Just pay shipping.
Sent from my Galaxy Note9 using Tapatalk
SWSS
Smashville
Thanks. Found a local seat track. Gonna get it swapped this week.
BigBodyBurban
