No 4wheel drive!
xeqshnr
Its been quite awhile since I had to use the 4 wheel in the Yukon. Yesterday I tried to lock it in and nothing. The 4 hi light flashes and the transfer case shifts but the axle wont lockin. If I remember right the last rime I used it it took awhile before it kicked in. But this time no go. Im guessing its probably the actuator on the axle but just wanted to post it up on here in case there are any common probs that would cause this. Thanks!
Sent from my SAMSUNG-SGH-I997 using Tapatalk 2
noJeepshere
Bountyfull, Utahrd
Pull the actuator off and have someone shift it into 4wd. If the actuator moves out, it's good. If that's the case, there is a bearing on the arm inside the diff that wears out. $13 part that takes several hours to replace, mostly because you have to drop the diff and split it open.
X
xeqshnr
Thanks for the advice! Ill lwt you know what I find, but knowing my luck its the the $13 part that takes hours to replace! lol
RedCrush
if the light is just flashing and the t case clanks when hit the button,,,, it the front diff actuator...
SunlitComet
OBS Jedi-Do Good
unknown at this time.
not necessarily. the switch that powers the front actuator or the feedback switch or the separate power circuit that powers them both could also be the cause. and yes even in internal mechanical failure can keep the front axle from locking in. even if the tcase shifts.
X
xeqshnr
Ok I heard it was gonna snow tomorrow so I finally checked into this lol. It was the actuator, $71 at O'reily's and I'm back in buisness!
RedCrush
Nice, Mine was doing that about 2 months ago. I just replaced the transfer case and now my fuse keeps popping. Hope its not a scaved wire somewhere.
Westernstar8806
