No gps signal
StephenW
My 2015 Yukon xl Denali has no gos signal - when you go to the built in map the system does not know where it is.
Anyone fix that before?
L8T BURB
Kentucky
Have you checked to see if your satellite (Sirius/XM) radio is working? If not, this is definitely an issue with the shark fin antenna on the roof of your vehicle. I had the same exact issue you are detailing here. Luckily my neighbor is a GM service manager, and he immediately commented that the antenna is the issue. I purchased one from Amazon for under $100, and it was a genuine GM part that was already painted to match my factory paint code. I installed it myself, under 1 hour total. Once completed, the compass, GPS, and satellite radio all came back on as expected. It does take a few minutes of driving for the compass and GPS to fully calibrate.
The root cause of this issue is that there is a "slit" in the rubber seal of the antenna that allows rainwater to drain right into the antenna. Call it a design defect.
Long story short, research GM parts sites to identify which part number you need, then search that part number on Amazon. Hope this helps!
Scpori
