No oil pressure at start up, 2001 Tahoe
2006Tahoe2WD
Silicon Valley
My 04 Z71 has 245k. These trucks last if you take care of them. I have had zero oil pressure issues since I put the O ring in. hope this thread eventually helps someone avoid a very expensive "rebuilt" just because a $3 oring goes bad.
Again, good write up. I'm watching my oil pressure and it is now 32psi at cold start and rev it up without change. So I think I have the O-ring issue.
2006Tahoe2WD
Silicon Valley
I think the issue is verified. The mechanic overfilled the oil about 2/3 quart? The pressure went up from 26 to 32 cold start. I read somewhere about testing the O-ring by overfilling and cold starting with the rear end up in the air. Yesterday (with the overfilled oil) I coldish started on a steep downhill driveway and the pressure went right to 40-45. I think this confirms that I have a pick-up tube O-ring that is not good.
nonickatall
Germany
So swap it, it's not a big deal. I did it myself. When you do it swap as well the pressure relief valve which also can make trouble and is accessible when the oil pan is down.
2006Tahoe2WD
Silicon Valley
Eddiec32
