Hi all...I have an 07 4x4 Yukon. My engine light came on and the code was showing for an Oil Sending unit. I had this replaced. When I drove the truck home, a warning light came on for Low Oil Pressure. The truck was reading 0. The shop changed out the Sending Unit again thinking it was a bad part. The truck is getting around 40 on the gauge until the engine is warm then it bottoms out again. They are now replacing 2 gaskets and the oil pump. If this is not wrong, I do not know what else to check? Has anyone had this same issue? Thanks
