No Rear Defroster
nicegy31
ok first thing you do is turn on the defroster and take a digital meter set it for low voltage dc. I had an similar issue and it was the connectors. If you have 12 volts at the two wires going to the window everything is fine. Just check the tabs on the window mine had a little paint on it and I had to clean them off with a small screwdriver and after that I tightened up the contacts on the connectors themself. If you do not have voltage you can go to the wiring and relay for troubleshooting.
Levi0320
