No Rear Heat
JesusArTorres
Tulsa, OK
My 03 Yukon gets no rear heat. The front works, although not fine. It blows warm. I know the engine has to get hot for the air to start blowing hot. So eventually the front starts blowing warm, but the rear blows its coldest always. Should I replace the rear actuator?
Red Rider
Hi Jesus, you really should do a search prior to posting since this topic is a common problem and has been talked about extensively.
Here is my post on subject of fixing on my Tahoe. http://www.tahoeyukonforum.com/forum/showthread.php?t=66001
Most likely, it is your rear controller. I think (not certain) that many people talk about replacing their actuators, but it is really a controller problem. The actuator is pretty darn simple device; i don't see how they can go bad, except if motor burns out.
JesusArTorres
JesusArTorres
Tulsa, OK
I snooped around the forum but not much helped. You can see my posts on these.
http://tahoeyukonforum.com/forum/showthread.php?t=65445
http://tahoeyukonforum.com/forum/showthread.php?t=66600
http://tahoeyukonforum.com/forum/showthread.php?t=66406
I will take a look at yours though, I hadn't seen it. Thank you.
QUYHMK
