No reverse (backup) lights
rendos
I have a 95 yukon that has no backup lights. I replaced the fuse and bulbs. Still nothing. What do I check next?
retorq
Kingman AZ
Yeah probably the unit sunlit mentioned, I had mine come out of alignment before.
The easiest way to tell, does your truck start in "N"??
willxfs
Could be the circuit board that the bulbs/sockets attach to. I've had 3 or 4 that have crapped out over the years and the reverse light socket is always the one that fails.
R
rendos
Yes. It is in reverse in 'N' and neutral in 'D' and drive in '3'.
---------- Post added at 06:55 PM ---------- Previous post was at 06:19 PM ----------
I replaced the board the bulbs attach to already. No change.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
your gear indicator indicates those readings? chuck it for a new delco one if adjusting it does not help.
R
rendos
Sunlitcomet - wow. Thanks for the detailed instructions. I will do this hopefully this weekend.
OmarRa
