No reverse lights. Wheres the back up lamp switch?
Bowzer
SoCal
Does anyone know where the backup lamp switch is located? Reverse lights no voltage. There's 12v at the B/U LP 25A fuse but no 12v at the VEH B/U fuse which is fed by the back up lamp switch.
dantheman
Houston
i believe its on the neutral safety switch on the side of the transmission.
Bowzer
Bowzer
SoCal
Thanks, you saved me from tearing into the dash for nuthin!
1_8TTony
Does the R light up on the guage cluster when you shift the transmission into Reverse?
If not, the problem will be with a part called the Shift Range Indicator.
Bowzer
Bowzer
SoCal
Thanks, R was lit on the cluster. Replacing the backup lamp switch fixed it.
ElMasBuscado23
