Well guys, you can officially call me a *******. So I charged up the battery fully. My plan was to go unhook the negative cable but as soon as I had opened the door to pop my hood my alarm went off and this was 12:30 am. I panicked because of the noise and tried to unhook the negative but I didn’t think about how the battery basically sits in the tray backwards so I’m thinking righty righty from the front of the hood and I tried hurrying up and doing it so I can disconnect it and turn the alarm off but I stripped the bolt. Finally alarm stops and I just quit till the next day. I guess there was some corrosion around the bolt and inner cable.
I got the cable bolts out and bought new ones. Again short on time and rushing to get the new bolts through the cable rubber housing seams impossible as the ring around the bolt is larger than the rubber housing. The guy at the parts store told me to heat it up with a blow dryer and see if I can get it in that way but seams impossible. Again I was short on time. I watched a video of a guy do it fairly easy using Vaseline to live it up and a small picker to work around the rubber housing. Any tips on how to get the bolt through?
Also regarding the unknown driver I called the dealer and he read about it and came up with a pinched wire underneath drivers seat. I don’t know about that but I also found this relearn procedure on the internet although I’m hoping it corrected itself after I get the battery back in.
Also I did have the battery tested at advanced auto and it came back good and I got some crc battery terminal spray to spray and clean with a brush
https://www.justanswer.com/gm/2qxkv-unknown-driver-reset-theft-security-so.html
