howdy all
i'm having an issue after swapping out my battery
yesterday w/o warning my '15 burb wouldnt start
hooked up jumper box & it fired right up
alternator gauge looked ok & ran my errand. all the auto stores were closed
this morning, same thing
so figure its about time for a new battery (4 years & didnt have this issue then)
so bought new battery
swap it out on my lunch break & think all is well.
...until i try & go to dinner. it wont start. i rec'v pop up msg about theft deterrent system.
i disconnect neg. battery cable for about 10 min.
reconnect & same issue.
(all connectors are clean)
saw a video mention while in vehicle hold down lock & unlock buttons on keyfob for 3-4 seconds.
recv a few flashes on mirrors & security dash light
still wont start
i disconnect neg. & pos. battery cable for about 20 min.
keyfob & door handle lock/unlock work fine
as does radio & everything else.
@ one point, it asked me to open & then close my drivers window
followed by opening & then close my passenger window
what is that about?
so i tried remote start for sh!ts & giggles, cranks right up (w/ both keyfobs)
{1 keyfob is new within last year
& main keyfob, changed battery today, just to be safe.}
go to apply brake & press start button... it dies & pop up msg about theft deterrent system.
even thought to unlock & lock w/ keyfob.... then unlock w/ backup key
still wont start
found multiple posts about touching pos & neg cable (after disconnecting) to discharge any residual charge
finally think, although remote start works... maybe battery is just a hair under required charge.
hook up battery charger for 15 min
still wont start
found thread on another forum, said to press start button in accessory mode. leave it for 10 minutes & see if security light goes out.
it auto turns off prior to 10 min. so cant test/validate this option.
currently, unhooked pos & neg cables & letting it sit overnight
b4 i try another time... then call dealership & try to talk to mechanic
*don't think it needs relearn of keyfobs, nor a BCM issue.
also not a starter motor issue
.... as i can lock/unlock & remote start it w/ both keyfobs
tried searching a few diff options, but seems i have already tried what i found
[theft deterrent / wont start / battery cable / ]
thoughts/suggestions?
still wont start
what is that about?
still wont start
still wont start
