Just Fishing
Can't fix stupid
I have been wanting to try my hand at doing gearing, and I might do it one day.
so far what I have done is to replace all of the bearings except for the spider gears on my S10 a few years ago.
How I did it was to take lots of pictures, measure everything, counted pinion threads.
Marked the pinion shaft and the nut for the exact position, and replaced everything with OEM bearings and seals.
that axle has had a good 100k since then and it's still kicking and solid.
When the Pinion bearing started going out, it got a nice solid vibration when going above 75.
then slowly got worse.
I also learned a little something from my Jeep.
the rear end apparently takes time to flood the axle shafts.
You can fill it, wait for 10min and it's still full.
Come back in 3 hours and it's low.
It looks like before I bought it someone changed the fluids but did the quick fill and plug.
Resulting in the level being too low to touch with my finger.
When I drained it, I got lots of shiny metal.
Wild guessing that it's from the pinion bearing due to low oil.
It needs gears for the 35in tires I want anyways, so It's just on borrowed time for now.
