Thank you very much!
Looked at it again and come to find out its a roller. Sprayed some lubricant and worked it back and forth. Seems to be ok for now, going to spray some white lithium grease when I can pick up a can. Thanks for the input!
Ill keep that in mind, thanks!I have to grease my drivers door every few months. Tried white lith grease but it didn't last. Pulled out some high temp synthetic wheel bearing grease and tried that- worked like a charm. Just can't spray it on like the white lith in a spray can.
