Noisy IAC, No start; fuel, IAC, or?
nimrod.sixty9
nimrod.sixty9
Hold on, I got this.
Okeechobee, FL
Got new cap and rotor and I have had instant fire every crank! Got rid of one screen in the distro so lets hope like hell all is good!
nimrod.sixty9
nimrod.sixty9
Okeechobee, FL
hi-res pics of inside old cap?
Old was deff corroded, but assumed I had cleaned it well enough considering how well it ran when it did run and how long it would take to build that much corrosion up.
It was pretty much spotless when I took it out and had no effect before or after.
New cap and rotor I can tell it starts way better than any of the previous run scenarios.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
the corrosion might have eaten into the conductor legs. the only real flaws i see in these engines is the dizzy cross firing cap and the old style injectors. everything else is great.
no burnt material of sorts, noticeable cracking or arcing?
nimrod.sixty9
nimrod.sixty9
Okeechobee, FL
I agree. I cannot fathom why they redesigned an injection system from scratch while MUCH better injectors have been available for years.
All I could really tell was crazy massive corrosion; not much else.
SunlitComet
OBS Jedi-Do Good
mainly to minimize part size and less complication. unfortunately the injection system just didn't work in the long run. gm even extended the injector warranty to 10y or 100k miles which was very generous of them considering the fact that there were hundreds of thousands of that engine out there. besides they like any car maker has to try new things and put them out in the field to see what happens.
ed70805
