ChrisAU
Sooo I got the TB rebuild done, unplugged the battery while I put it on to reset the ECM, plugged the battery back in after I was done and did a IAC relearn before cranking it. Immediately obvious that the passenger side injector was leaking, so I cut it off and redid all the o-rings in the pod. Cranked it back up, no leaks. But it runs like ****. It stalled the first time I put it in drive. However, after re-cranking it it did start to run better and it didn't stall the next time I put it in drive. Its been suggested that I run it 30 miles or so after a re-learn for it to get perfect, so we'll see. I needed beers while doing this and since my rear bumper is removed I don't have a license plate, so I'm not driving it tonight.
TB Before:
TB After:
TB Before:
TB After:
