O2 sensors?
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
This pic does not show a separate pipe.
They show one of the cats connecting to the "Y" section between the piping at front of muffler to the back of the D/S cat but I see no separate pipe.
The supplied pic shows as one piece but other manufacturers show a 2 piece set up.
tekfire07
tekfire07
Here is the Walker brake down.
This the part I am referring to.
Erik
Stock and that replacement from Walker are indeed 1 piece designs. My Magnaflow is 2-piece and has much better piping that flows better by itself.
I got the P0420 code. I tried a cat cleaner it worked short term. But the code came back. From research it seems that cat replacement is what will fix the problem. Because of finances I am looking a Walker OE direct replacement bolt on cats. I am considering replacing the system completely all new. The one thing that I can't find anyone have in stock is exhaust extension pipe that goes between the cat pipe and the muffler. I thought about doing only the O2 sensors. But I don't want to mess them up if the cats need to be replaced. Any input is appreciated.
Erik
New O2 sensors are not going to cure a P0420 if that's what you're thinking. You can replace the Y-pipe (with cats) without replacing your stock exhaust behind it.
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
Ok, I was looking for a "pipe only" and not a pipe/resonator. I am old. You have to be specific.
Example of this is the way I missed the vehicle info in your first post.
tekfire07
tekfire07
Good to know it is also known as a resonator. Walker just calls it a extension pipe. This is my first Tahoe. So I am learning on the fly. I appreciate your help and feed back.
Erik
BG1988
it cured a P0430 for me ( that is bank 2 as to P0420 which is bank 1) but i all ready tested the cat with AFM and DFCO off..
tekfire07
tekfire07
Are you running a complete Magnaflow system Cats and Exhaust? Have you noticed any improvements in HP or gas mileage?
Erik
Erik
Well, after replacing the bad cat with a whole new Y-pipe my gas mileage certainly did get better. Since we were drag racing the truck, we did measure a 5 horsepower improvement as well. Not enough to feel but the mph in the quarter mile went up some.
Just the Y-pipe with the cats, still running the original exhaust behind it.
carloogbuyNuh
