OBS 5.7 stuff
ktmhans
Connecticut
Cleaning out the shop. I had a 1998 tahoe vortec 5.7 so that is what most of this was used on.
Cat engineering stainless roller rockers. the were used for a short time. Nothing was wrong when removed. I have half 1.5 ratio and half 1.6 ratio. They are for the vortec heads and are self aligning. I havr the locks for these also $55 TYD in lower 48
Comp cams roller tip only rockers. Part #1418_16 self aligning as well. Used can remember how long , maybe 15K or so. I have the nuts but you may want to buy new ones. $55 TYD in lower 48
2 factory rear axle bump stops in good shape with the hardware. I took them off for airbags. $15 TYD " "
2 electric fans
1 single fan that has a 2 lead plug, I bought to go on tahoe and never got around to it. $40 TYD " "
1 double fan that has a 4 lead plug. $60 TYD " "
Fans work
I have taken pictures so I can email on request and will work on getting em up
thanks hans
gmcconvert
what size are the fans? does the single fill the radiator and fit inside shroud? any idea about cfm from either single or double. thanks.
K
ktmhans
Connecticut
Sorry for the delay. I beliece the shroud would be.removed. the single fan has a type of factory bracket on the top. Not sure of the cfms . Send me a pm with your email and ill put some photos out to ya. I can measure the up tomorrow.
K
ktmhans
Connecticut
I would be happy to email them to ya. Ive never figured out how to put photos on a forum. Are there any directions around here?
MrsMfcknMcDonald
