John03Z71
- Joined
- Mar 27, 2014
- Posts
- 43
- Reaction score
- 14
I noticed this leak yesterday evening about an hour after I parked in my driveway. I went outside to take the garbage out and noticed a wet spot about 12" in diameter on the driveway almost perfectly centered under the engine. It was dark so I took a flashlight and noticed a coolant dripping constantly (a drop every 10 seconds or so) but couldn't get too good of a look last night to try to trace it. I crawled under and peeked up and it does seem to be trickling down from the water pump area, but I couldn't get a good view of anything that might be the source (up higher, weep hole, etc), just a trail of coolant. The vehicle sat overnight and when I came out this morning to get in (after sitting for 14 hours) the wet spot was still there, but not quite as large in diameter (maybe 6-8"), but I could tell there were still very fresh drips. Before I go tearing into it trying to track down the source, hopefully I can eliminate and narrow down a few things with this post. Will the water pump still leak after the engine is shut off? Mine was replaced about 5 years ago as an FYI. What else could be the possible culprit for constantly dripping even after the engine is shut off? I haven't gotten a low coolant level message yet but plan on picking up a few gallons of 50/50 today until I figure out the problem.
The 'T' connector on my heater core was leaking in the winter when I ran the heat, but the wet spot it created was in a different area on the ground. I haven't gotten around to replacing the 'T' connector yet. I also noticed I no longer have front heat. Not that I need it in July, but on a road trip this past weekend I tried adjusting my A/C temp up from 60 to 72-74 and noticed no difference, so I turned the compressor off and cranked it to 90 and let it run for a few minutes and it was just fresh air. Not sure if its related at all, just throwing it out there.
Thanks for any info.
