OEM denali headlights
rippinitup
NY.
i have an 03 yukon with 4500k 35w HIDs, i love the upgrade over stock but the light pattern is disgusting.. how are the stock denali headlight projectors?
thanks!
Physh1
Well, yes the light pattern sucks. HID's are not designed for halogen housings. The oe Denali projector is a good start.
DenaliAK
Colder than you
Alaska
Just about any projector is going to be an improvement over the stock halogen reflectors.
2005yukonxl
not true. most of the chinese projectors (the ones with all the hondaesque pointless little LEDs in them) have alot less output than the stock lights....alot of them are so bad they are dangerous.
DenaliAK
Colder than you
Alaska
I've said for a few years that 99% of aftermarket lights with useless LED's and cheap Halos are absolute crap and to not buy them. People don't listen cause they want a look.
I could have gone the other way with it, though: The only way to insure good HID output is with an HID projector or a reflector designed specifically for HID. That means, if you're serious about getting the best results, the only option is to retro in an HID projector. All other results will fall somewhere between "bad" and "better" output instead of "best".
Bottom line is that yes, the Denali headlights are going to be an improvement over the yukon lights with HID's in them. They will not be perfect, though, because they aren't an HID projector, they are a halogen projector.
rippinitup
rippinitup
NY.
thanks for the replies guys. can i buy somewhere headlights with the HID projectors in them? or is a retro-fit the only choice?
Scope75
X2
Would like to just buy them and install instead of modding new or old housings.
DenaliAK
Colder than you
Alaska
No, not really.
You can have a custom shop do the retro for you, but you pay a premium for that. I have never seen an aftermarket light that came equipped with actual quality HID projectors, although they may claim it.
Mikegrz
