if the wires are the same then the signal to turn on the bose amp is digital from the radio, so in a sense yes it is a chip, that's why if you go to a aftermarket headunit and have bose it requires a adapter module and that module will send the signal to turn on the bose amp and retain rap, without bose you can just use a cheap wire adapter but you loose rap, because rap is provided by another chip in the radio. If you have rse that is another thing provided by the radio and also requires a adapter if you go aftermarket.
