OEM NAV question
phileaglesfan
Utah
I searched the topics but some things are not clear.
I would like to enter a destination while driving. I have a 2009 Denali XL with OEM NAV/Rear DVD. The disk says it is version 5.0c. I read about the lockpick device but I also heard there was some issues with it. At $250 it seems like an expensive fix especially when a Garmin the same price allows you to enter the destinations while moving. We could care less about playing the DVD on the front screen while moving.
I have bluetooth already and OnStar works. What is the IPOD lockpick? Can't the IPOD just be hooked up to the radio? I thought it shows the categories already.
I understand why GM did this lock but we do click agree every 50 times or so right?
Thanks in advance.
SabrToothSqrl
I assume this disc works in the chevy too? I have a 4.0c disk... hmmm...
bjc7jr
PA
as far as i know, in order to contol your ipod through the radio you need to have a usb connection in the radio. the new terrains come standard with this. Thats prob what the lockpick provides. I don't know for sure though
jeffbco
Thanks in advance.
Lockpick will allow Nav changes while in motion.
iPod Lockpick allows iPod to be controlled by radio.
Two separate devices.
www.coastaletech.com
SabrToothSqrl
vss
rumor is that if you add a switch to your VSS wire behind the nav system, you can enter address destinations / scroll address book while rolling... then flip the switch back for normal operation... i have not tested this, but hope to when I get the time. reports from other forums state it DOES work for this.
bjc7jr
PA
That would be great. What forums did you find this on? Would you mind posting a link?
jeffbco
Can't remember the exact link - try to Bing or Google "Navigation VSS modification" - you'll get some hits.
P
phileaglesfan
Utah
Before you start cutting wires, I would research it throughly. I heard some people having issues especially with the newer units.
Tonygxp
Toms River, N.J.
can you be more specific about hearing there are issues with the splice or disconnect. I know a GM A tech, i will see if he heard anything and maybe c if he can do it for me, but would love to research it on here. thanks
dabsnabbs
