OEM Navigation in a '04 Tahoe LT
Anthony
2004 Tahoe LT (MA)
Westen MA
Hey guys,
A quick question, My friend has a 05 Escalade with OEM navigation and is taking it out to put in a Alpine 7 inch LCD. If he sells his OEM navigation to me (I have Onstar/Bose/XM) Can i just use it as "plug and play" or do I need anything special to make it work?
Thanks,
Anthony
OmarR
Indianapolis, IN
You need:
His amp or another LUX amp
Rewire the amp connector to accept new amp
GPS antenna
The dealer to clear out his VIN because it will be theft locked.
Possibly wire in the VSS wire from the tach wire on the cluster
If your buddy also throws in his stock amp and you do the install, you will probably spend about $120 ($60 for antenna, $60 for dealer VIN clear).
NathanJax
Vacation Nathan
Administrator
Jax, Fl
You need:
GPS antenna
+1
You need a non LUX version of the factory navigation. I have one for sale on eBay right now because I got it and I needed the LUX version...
NathanJax
Vacation Nathan
Administrator
Jax, Fl
Can you post the link or tell me what you want for it?
The Touchscreen NON LUX is sold. I also have a non touchscreen lux navigation that I will be putting on ebay soon if anyone is interested
Chamkila
is the one with square corners the non lux one and the round corners the lux one?
NathanJax
Vacation Nathan
Administrator
Jax, Fl
no.
03-04 non touch (either can be LUX or non LUX) not 100% on this
05-06 touch (either can be LUX or non LUX) I am 100% on this
NathanJax
Vacation Nathan
Administrator
Jax, Fl
UPDATE...
Only Escalades and Denali's have LUX or Luxury stereo systems, ie. Radio, Amp, CD Changer, etc.
SLT/LT/Silverado/Sierra/Suburban/Yukon/YukonXL/Tahoe have the non LUX systems.
You can get a LUX head unit to work in a non LUX vehicle (and vice-verse) but Programming the radio from non LUX to LUX or vice-verse can NOT be done at a Dealer with the Tech2. There is something about the NAV radio programming that is proprietary, and only people with access to Delphi base programming can change the radios. A Delphi repair house (Specmo www.spemco.com) can do it for a charge. But it sounds like your better off just getting the correct radio you need. There is a guy that was doing it for the website listed below for $75 plus shipping both ways. He no longer visits that forum, but his eBay name is supposedly maxpower_mi
Touchscreen model numbers
Newest revision LUX TNR-------15800001
Second Revision LUX TNR-------15230099
First Revision LUX TNR---------10377531
Newest revision non-lux TNR-----15800000
second Revision non-lux TNR---10379287
First Revision non-lux TNR-------10377287
Alt. Revision non-lux TNR---------15120706
Non Touchscreen model numbers
Newest Revision LUX INR--------15204335
First Revision LUX INR------------15204334
Newest Revision non-lux INR----15108241
You can read more at http://www.dieselplace.com/forum/showthread.php?t=40437
I can make a good thread/write up and try to get someone to make it a sticky if you'd like... Instead of reading all 100 pages of the link (plus another 56 pages in his "part 2"
Chamkila
so it is true i can have a lux touchscreen nav head unit in my 2004 Yukon XL denali with bose???
NathanJax
Vacation Nathan
Administrator
Jax, Fl
Yes, your denali should be a lux (luxury edition) and therefore, you should be able to purchase any radio with the model numbers 15800001, 15230099, or 10377531 and have the dealer reprogram the VIN in for you.
Dave00
