Oil and filter recommendations
DaRosa218
The Dude abides
Modesto, California
it has a
GM went to the future and came back with the variable oil pumps ..
If you google viable displacement oil pumps it will only refer back to 2012 as being new tech.
it's a high performance oil pump for the Lxx engine
it's a frankenstein LS2 based engine RPO LFA and LZ1
It’s available under p/n 12625823 for the LFA and p/n 12623423 for the LZ1
apparently it saves 2 HP from being wasted :)
HP is
332 hp @ 5100 RPM(248 kW) 367 lb⋅ft (498 N⋅m)4100 RPM Combined output is 379HP/ 472 lb-ft..
some people might consider this a VERY HIGH OUTPUT engine lol
VHO 6.0L
it has a 4 or 5" aluminium drive shaft it's big though i'll measure it later
Ok, so you have an LQ9... got it. LOL
DaRosa218
The Dude abides
Modesto, California
RPo LFA it has VVT and AFM aluminium block
basic slapped random parts together and built them
So you have the hybrid motor? LFA's were factory options in the 2008-2009 Hybrid SUV's/Trucks. The LZ1 replaced the LFA in 2010 for Hybrids
HiHoeSilver
Away!
Chicago
Yes. His is a hybrid. It's a super special magical one. It is both the greatest vehicle GM ever built and a total piece of junk that he is lemon lawing. Dont ask him about it.
BG1988
you think this is satisfactory and safe when you buy something that is proclaimed as being in satisfactory condition and "safe"
I asked for the records for the SUV they refused because they claimed the dealership owned the "inspection records"
they know they are SCREWED as the records are FALSE.
they even did a illegal smog test as well. (at lest it would have failed the physical inspection part) DRY wall screws holding up fuel housing/ hose
very legal and safe if you ask me (if you did not know I was being sarcastic )
a
Nemo_B4
