2012 GMC Yukon Denali XL. Always do my own oil changes; 15 minute affair at most. Probably done it close to a hundred times. Never, ever, ever had a problem...until today.
For some reason, the oil filter seized and would not come off. I use a Mobil 1, M113A. Has always served me well. I put the oil wrench on, and the damn thing would not budge. The oil filter wrench broke trying to get it off. Tried the screwdriver method, that made things worse and simply ripped the filter in half. I basically had to gut the entire thing, get all the way up to the top ring, and then finagle some insane way to get it off the truck's oil screw. All this done having the equivalent amount of space as a carton of juice.
Needless to say, it took me 9 hours. After beating on the ring, trying to get it to turn unsuccessfully for about 8 hours, I finally drilled some bolts into the holes in the top part of the oil filter, and used some lock pliers to basically twist it off. That took me an hour. I was home free after that.
What the hell happened, and how can I prevent this in the future? I bought a new oil filter strap wrench. I also hand tightened the new filter when installing: no more wrenching it on.
