Oil/Fluids?
Smasal
Southwest, Mo
Doing these tonight....going shopping now. Recommendations? My engine only has 12k on it but the tahoe has 127k on it? This affect what oil I should use?
Transfer Case?
Oil?
Rear and Front Diff?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Need to know what kind of 4x4 system you have for the tcase and front diffy.
Engine: Mobile1 synthetic and a K&N filter.
Rear can use gl-5 80w-90
SunlitComet
OBS Jedi-Do Good
Why?
---------- Post added at 01:05 PM ---------- Previous post was at 01:04 PM ----------
do you have a locker of some sort and if so what kind?
Smasal
Smasal
Southwest, Mo
I don't think I have a locker. I posted a pic of my sticker that's in my glove box in a different thread. And couple guys told me I had limited slip and 3.73's. But I'm not entirely sure. He said he pulled up what I needed and it says I need this limited slip additive or it will chirp and shutter on me in the back. And could tear up my gears.
Ch@d
SunlitComet
OBS Jedi-Do Good
Based on YOUR VIN, you have 3.73 gear ratio with an open differential so unless you have other proof like paperwork or a visual inspection of the differential yourself stick with the gl-5 fluid and tell the Oreilly to stuff it. Or give me the number and I will. But get your fluid first then I will call.
and for below you have a gmt400/K10706 model unit:
77985694
Smasal
Smasal
Southwest, Mo
Nice. There are actually 5 locations within 20 miles of me and this is the one I never go to unless I know what I need/want. So I got the oil already. I'll return the additive. Thanks again man. No need to call. I like confrontation. Don't work somewhere if you don't know your information.
Ch@d
conrual777
