Oil/Fluids?
Smasal
Smasal
Southwest, Mo
Is there a chance someone added limited slip when? It has a salvage title.
Will I be able to tell when I get the cover off?
What tire do I spin to check when it's off the ground
Ch@d
SunlitComet
OBS Jedi-Do Good
unknown at this time.
tie check is not always accurate just take of the cover since you need to to drain fluid.
This is a open differential:
This is a G80 differential on drugs:
Any questions?
---------- Post added at 03:35 PM ---------- Previous post was at 03:32 PM ----------
This is a g80 about to start using:
Smasal
Smasal
Southwest, Mo
Cover is off. Anything I should look for other than metal shards. Is limited slip something I can tell?
Ch@d
SunlitComet
OBS Jedi-Do Good
---------- Post added at 03:39 PM ---------- Previous post was at 03:38 PM ----------
Your pics that is. I love technical documentaries.
Smasal
Smasal
Southwest, Mo
Ch@d
Smasal
Smasal
Southwest, Mo
Can u see these? Tapatalk makes them small sometimes...
And is me, or shouldn't there be a seal or sealant around this thing?
Ch@d
SunlitComet
OBS Jedi-Do Good
First off :doublepuke:on the gunk thou gears look clean.
Second, it looks open but rotate 90 degrees so I can see the inner gears.
Third it uses a gasket normally but it is a good idea to use gasket sealer on it as well.
conrual777
