Oil Gauge Reading 80 PSI?
ChazMan
ChazMan
So Calif
Not yet. Probably won't get to it til next week at the earliest.
No hurry...
But when you do, please take some pics and post here. I just can't find where it is nor what it takes to replace one.
Thanks!
tsb09000
Thread Killer
Well it's fixed. No pics since we were losing daylight fast but there wasn't anything to take pics of really. It was pretty much a pain, but all in all it wasn't too bad and didn't really take all that long. I basically had to sit/lay/stand on the radiator support the entire time to get to the sending unit. We used a 27mm deepwell socket, several different extentions and a swivel to get the little bastard out. I looked from every angle but could never see it, so it was all done by touch (and luck).
ChazMan
ChazMan
So Calif
That's a good tip!
So, which side of the engine block is the oil pressure switch located as you are sitting on the driver seat, left or right?
tsb09000
Thread Killer
It's almost centered on the top of the back of the block but slighty more on the driver's side if that makes sense. If you have a light and a small mirror you should be able to find it, then just unhook the wire and switch them out. Like I said, we pretty much did it blindly but the mirror did come in really handy!
wfstewart
