Oil life
Big Mama
Virginia
Mostly goes by miles. Take the 3200 miles on yours and see what 3200 is 54% of. I'm no math whiz but I'd say it's around 7000 miles which is close to what my owners manual says. I try to follow the manual. They set the frequency for a reason. Also keep receipts in case you have an issue and you need to prove you did your part.
Miami-Dade
Super Moderator
Your right Big Mama..I feel better now..Thanks.
Big Mama
Virginia
Glad to help. Take care of that truck and you'll be amazed how reliable they are. I use the cheapest OnStar subscription, I think less than $10 month and get the reminders for all services needed from rear diff to air filters and if I'm locked out they open remotely. I had to use it dang dogs locked me out with it running. Good luck
Miami-Dade
Super Moderator
Thanks for the info on OnStar..Had no idea I can get that low rate for all those reminders..I will get that as my feebie for it is about up.
