Oil pressure issue.
UPSdriver
I have a 2007, 5.3 Yukon xl 1500 SLT. I rebuilt the top of the motor last year , getting rid of the DOD. The vehicle has 226000 miles on it. Runs very well. I am a little frustrated with the oil pressure. When the car is cold, the oil pressure will get up to 60 during driving and idles around 40. After the car warms up, it idles about 20 and 38 during driving. There is no ticking and she runs very strong. If. When I change the oil , it helps for a while. Is is possible the oil pickup tube o ring is the culprit? I had the oil pump replaced about 20k ago but I don’t know if they replaced the o ring. Would it be helpful on a high mileage engine to run a thicker viscosity ? Thanks in advance for any guidance.
rdezs
When the AFM was deleted, did you remove the oil pressure relief valve mounted in the oil pan, and plug it? If not, those relief valves get weak over time and could be releasing pressure. If you do go in and drop the oil pan to take care of that, I would definitely go ahead and replace the o-ring while you are in there.
If that was addressed during the AFM delete, and the towers are plugged under the valley cover, the only other source for pressure loss other than the oil pump itself which has a built-in pressure relief valve..... Would be excess bearing clearance. Usually the cam bearings.
What oil filter are you using and what weight oil? Some brands of oil filters seem to have more of an effect on oil pressure than others. You might try a Wix XP. If the oil ports have been properly plugged, and a change in oil filter doesn't bring results, at your mileage I would try a 10w40 full synthetic.
Keep in mind GM recommends 5W30 in North America..... Most people assume it has to do with the fuel mileage requirements for the fleet. Because in the rest of the world GM recommends 10w40 in most locations for the same motor.
donjetman
1st, you don't have a problem. You may want to have a problem, but you don't.
A thicker oil (higher viscosity) like Mobil1 5w50, Redline 5w60, etc, etc, should increase the oil pressure (resistance to flow). Also use a oil filter that isn't a "high efficency" filter like a Wix, NAPA, etc, etc.
Another oil system leak source is the barbell/dogbone in the oil galley above the oil filter. Tranny has to come out to replace it.
rdezs
I completely forgot about the dog bone in the rear. Never seen one leak though, the OEM plastic ones seem to do their job forever.
While GM considers something under 10 psi at hot idle as acceptable, I think we all know that a healthy LS vitals in excess of 25 psi hot. If it's recently dropped down to 20 psi I would call that a concern, but not enough to be extremely worried about..... But keep in mind if it's dropped to 20, it may continue to drop. That's where the concern is. At over 200,000 miles with unknown frequency of oil changes over its life, it's quite possible that 20 psi is due to normal wear in the bearings. If that's the case it will probably run for years, eventually slipping down to 15 or 20 psi and still continue to run fine. The heavier weight oil is a good way to address that.
Charlie207
LFOD, New Hampshire
My rebuilt engine sits at 38-40psi hot, when cruising at 1400rpm. That's normal.
Dropping to 20psi at a hot-idle is probably worn oil pickup o-ring, or maybe even worn cam bearings. Did you replace those bearings when you did the DoD-delete?
With that mileage, you absolutely don't have an oil pressure issue, IMO. I just had a new oil pump and o-ring installed, and my oil pressure is just about the same as yours. And, prior to my replacing the oil pump and the o-ring, I had exactly the same oil pressure, as after replacement.
rdezs
Well, let me put it this way. When you rebuild an LS engine and verify all the bearing clearances, and with the OEM oil pump and oil pressure spring, it will idle hot all day long at 35 PSI. As they age I've seen that number very gradually come down. Sometimes it's due to o-ring issues and other things..... But when those are addressed as mentioned above, and the oil pressure remains at 20 psi.... Will you have left is bearing clearances. According to GM that's just fine and not an issue. They find 10 psi acceptable. (!!!) And granted, it can go for another hundred thousand miles at 20 psi hot idle. Usually. I think the biggest factor and gradually increasing bearing clearances is definitely something we all know..... More frequent oil and filter changes slow down that process tremendously. I understand the GM oil life monitor is actually highly rated, and was done with several years of study with oil analysis. I'm just not sure, and I have my doubts, if their studies were actual real world conditions. I feel the safe bet is to change it every 3,500 to 5,000 miles. (The oil life monitor can vary all the way up to and beyond 8,000 miles.) I will say I have a co-worker with a 2014 Silverado pickup with the 5.3, he changes his oil once a year around 10,000 mi and he has 165,000 miles.... And holding about 32 psi hot idle. He drives it easy, and he commutes 15 miles each way to work on a 55 mph highway with no stops. Everybody's real world experience is different.
Where did you learn of this oil weight recommendation for overseas vehicles?
I don't see a problem, my oil pressure sits at like 19 after it's really hot and at 39 cruising on the highway. Been like that for years.
That about where mine has dropped to lately. Three months ago it was 4-5 psi higher, highway is the still the same.
Mily
