Vehicle: 1995 GMC Yukon, 5.7L TBI, all stock
Since I bought my Yukon a while ago, it's had a very slight miss at idle that would happen on and off. Never fixed it because I'm still getting 17-19 mpg on the highway and 10-14 in town.
A few weeks ago my heat shield (or so I thought) started to rattle while sitting at idle, never really gave it much thought. Today I was at a drive through and the miss was a little more noticeable but when I looked at the instrument cluster I noticed my oil pressure going between 20-40 (back and forth) at idle, mainly stayed around 20-30 lbs. The rattle I thought was the heat shield would change in pitch with the fluctuation of the oil pressure (louder when oil pressure dropped). This was with the transmission in drive and my foot on the break. Start up when cold my oil pressure is around 60, when under power (and the engine is warmed up) it stays at 40 or higher. The oil pressure does not fluctuate at idle if the transmission is in Park.
Any ideas?
Vehicle does not use or leak any oil, checked intake gaskets and crap right after I bought it.
Any ideas?
