Oil Pressure Sensor Keeps Failing with Oil Leak
O
OutandAbout
Curious, when you flashed the modules did you use the ones in TIS2000? Did yours show newer calibrations available, and did you use them?
Yes and yes. It tells you what needs flashing. The TIS2Web doesn’t show anything newer than the TIS2000 when I search the VIN. I do have the last TIS2000 version though from March, I think anyway. I’ve heard there may be an elusive later version from October or November but have never tracked it down.
Fless
Super Moderator
Elev 5,280
TIS2000 should have an old date (version), and it's not been updated in many years. Chances are you have the final version, especially based on your comparison with TIS2Web.
It's not like TIS2000 is being updated any more.
O
OutandAbout
Yeah, good enough for what I need with the 2005 Tahoe or anything older if I pick something up. My 2018 Sierra I run the GDS software and will prolly get the TIS2Web subscription for its vin. I know there is updates for shift clunks, need to get the current calibrations and compare to TIS2Web website.
BabushkinMechanic
Buford, Georgia
Just curious, any one else have a tiny hole in the middle of thier oil sensors.
The first sensor was from Amazon $15 and had massive leak like above post.
So I got one from rock auto GM part $50.
It also has a tiny hole but a lot smaller.
Garage2010
