Matthew Jeschke
Okay, so I thought I had a post on this somewhere but cannot find it. My 2001 Z71 Tahoe is at nearly 240,000 miles. I bout at 225,000 miles. Has 5.3L v8. I'm wanting to swap out for a 6.0L and hoping this motor holds together until then. It's had some minor annoyances but this is the only one that concerns me...
I'm running 5w-30 oil and is pretty hot where I live.
1. I start up the truck... after which it takes a little while to build oil pressure. Oil pressure fluctuates a bit as well once idling. But seems to maintain a good pressure.
2. I turn off truck and wait about 30 seconds... then restart it. Same symptoms persist, leading me to believe block is quickly bleeding oil pressure somewhere.
I thought might be a bad oil filter / drain back valve so I bought a Wix filter and swapped it on but seems to continue to have same problem.
I'm wondering if this might be a sign of heavily warn main bearings.
