Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
I'm not sure the reading - but past the half way mark. I just had it last week end dip below - and it kept failing till the warning system came on and told me to stop the engine. lucky I was close to home, and the next day I took it for an oil change, and it was all good. Cold after the change the needle points about 75% around
Literally just fixed the same problem. (i Hope!)
Happened to my wife late last night. I just did an oil change and it seems all good. I found out though (other members please correct me if I'm wrong) that you MUST use synthetic in these engines. The mechanic that did my wife's last oil change just used conventional and she ignored the change oil light. So my fingers are still crossed but after an hour long drive the pressure seems good.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
