Ok. Issue number three for today.....
dropmech
Puddle Pirate
Coral Springs
So I have installed a set of Recon LED tail lights on my 06. The brake lights work, the blinkers work and the reverse lights work. But I noticed that the normal tail lights don't illuminate when the lights are turned on either manually or in auto mode. What gives?
LuSe4
Bleen Member
Michigan
Do you have them plugged into the correct sockets? Sounds like the two that are not reverse lights need to flip.
LuSe4
Bleen Member
Michigan
I am not familiar with the recons. I know that I had to switch mine around and that they had to be plugged into the correct socket.
Are you certain they worked correctly with your stockers?
CustomTahoe01
when you install new led tail lights, the order of the reverse, turn signal and brake lights arent always the same. i had to swithc the order due to the fact thats the way the tail light was designed, double check....
2005SnowKon
Fort Collins, CO
Are those the red smoked once. I've been throwin the idea of gettin recon lights for awhile now
Xnown
