One More Time
04xl
I have been searching the forums and online and found a lot of good information on this subject but it seems like everyones suv is different.....The Service Ride Control light came up on my 2004 Denali XL Now i have read that people have easy fixes like leakes all the way to full replacement of compressor and shocks...My question is if i am doing a 2/3 lowering kit and 24s on it am i going to be disengaging the autoride? Will it be disconnected due to the lowering? I don't tow anything with my denali and don't plan on it... any info helps thanks!
zaathur
to remove the autoride you will have to install normal socks on it and i would just remove the fuse for the compressor and the leveling rods that are connected to the control arms
04xl
04xl
also last few days it goes on and off....One time I go in the car and i hear the compressor and there is no service light...then couple hours later when I get in the car I dont hear the compressor and the light comes on.
zaathur
i would do this check list
-connecter going to compressor
-the ground wire is good on the wiring harness to the compressor
-the switch that controls when to shut the compressor off and on its what the leveling rods are connected to
westcoast
Salinas,CA
with a 2/3 you keep your autoride. You can disconnect it if you want simply disconnect the battery and pull the fuse and reconnect the battery so you wont get a error message.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
pull the rtd fuse and your autoride light should go out and you can put whatever kit you want on it.
04xl
04xl
ok thanks for the info... MY Denali is at the shop getting lowered and the 24s put on it... im excited to see it and get her back:party33::party33: Ill have to post up pics. And is the fuse labeled RTD?... once i pull that fuse it will get rid of the message and then i can do whatever i want with the suspension..
