Drumrunner
This week i had to do a water pump, hoses, and a new stater. Truck hasn't run since last week. Its been giving me problems starting when it sits so i went ahaed and pulled the upper intake. I could tell by the clean spot that i was leaking fuel. I did the injector upgrade and it still won't start. It does the same thing it did before. It will crank then stop like the timing is way off. I have plenty of fuel and spark. I replaced the crank sensor a few months ago. Pulled the plugs and they were wet so i cleaned them up and put them back. No check engine light and all the injectors are installed correctly. I'm at my wits end.
