Opinions on Potential Denali Mods ...
Administrator
What size tire did you go with, serge?
Denali0229
FL
Looking good serge. After I get my system in, next mod will be the G4s. Hopefully I get a good set.
felixgun
Lafayette, LA
Is it the same for AMP RESEARCH steps? I have heard that the oem ones are almost impossible. I know the AMP ones will look slightly different but it would be close enough probably.
Not sure if the same but if it's aftermarket then I'm sure there's an aftermarket switch they'd have to add in there. And I was after the chrome strip along the running board bottom... Wonder if the amp ones have that or not.
soulsea
soulsea
Bar
There is a stainless steel strip available for the AMP but it has a different location ... it's curved at the outer lip of the steps and not flat along the sides.
---------- Post added at 12:05 AM ---------- Previous post was at 12:01 AM ----------
---------- Post added at 12:07 AM ---------- Previous post was at 12:05 AM ----------
felixgun
Lafayette, LA
Meh those are ok. Your oem ones take the cake though.
Jillb
