Ordered & went with a 2/3
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
with shock extenders it wont pop out no unless person who had your truck before you replaced with shocks that are longer then stock. and yes like all the tahoe/trailblazers the shocks are the thing that limits how much lift you have on axle
hoe
hoe
get the shocks changed out. the djm 3/5 (tb 4 inch rear springs) rides better then cranked keys/3 inch combo set up. but you didnt want to go that low.
Yea didnt want to go that low, but is it possible with the right drop shock it drops even lower? (are my stockers holding the ass up?) The overall ride is not that bad really, but just worried about catching air or extention will the spring pop out?
Im going to decrank the stock keys and call it good. Cause my truck is a 2wd and the front will drop quick. So may have no need for keys. Rear seems pretty high still, hope it settles.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
if you jack up truck now and springs dont come out they wont come out on extension when you are driving.
with a 2/4 drop rear sits 1/4 to 1/2 lower than front
with a 2/3 drop rear sits 1/2 to 3/4 higher than front
hoe
hoe
Thats the thing they did while I let the axle down while the frame was on stands. I had to use a spacer on the jack to lift it extra high to remove the jacks from the frame. So Im thinking if the frame jacks up high enuff it may pop? maybe Im wrong there.
I decranked my stock keys, about 8 turns from the max, and its alot lower than the rear (rake) which I hate, so I cranked the stock Tbars all the way back up but out 2 turns, and it looks alot closer to level, but may still need to turn it up 1 more time to perfectly get the truck level with the rear.
With the stock tbars max (2more turns) and stock rear springs, the truck sat about 1/2" taller in the rear still. So It prob droped about 1.5" overall net vs stock spring. Atleast it can be perfectly level now.
hoe
hoe
Back measures 36 5/8 on both sides after the 3" springs and shock extenders. I still have some rake in the front with only 2 turns to max out the keys. front is still lower by a inch, so Ill try to get it perfectly level and snap some pics.
hoe
hoe
Ok after looking at the pics from b4 and after doesnt look like I did anything to the truck... Im starting to think I did something incorrect. I think that the shock extenders may have been installed wrong, cause I found a pic of another extender and it was turned down almost like the reverse of what I did. Here is the pics I found
Mine is installed where the ends are point upwards... So Im thinking about going back and seeing if I can flip them to point down, then resinstall the shocks
---------- Post added at 08:29 PM ---------- Previous post was at 06:59 PM ----------
Got the arse to settle properly. Luckly I found that pic of the belltech shock extender. The DJM instructions were not to helpful. After reading the thing several times, I had to look at the picture they sent to even make sense out of it. Then I tried different ways to position it like the belltech pics, and only 1 way made sense.... I took the extenders off, fliped them down, and it brung the rear shocks lower to the ground. I then jacked the axles to tighten down the shocks. Now Im comfortable that if I catch air, the springs will stay in place. But I can ever so slightly spin them around. But aint no way they could flyout like I had them before. It may also be possible thats what the isolators are for, to keep them from spinning.
Now that the rear is fully dropped properly, IMO its a significant difference. It now looks like a 3" drop happened in the rear, not a 1.5". The arse is now way lower than the front, so I have to back out on the Tbars for adjustment now, and I may even need the keys that came with the kit this time. Im sure the ride is totally different now too, it wasnt bad before, but I can imagine it feeling real good now. Ill post back results.
:hands:
hoe
hoe
I will as soon as the rain stops. IMO its rides 1000 times better. Even better than stock as I had my keys maxed to raise the front. Now with 2 turns down from max (still alot cranked) It rides smoothe as silk. I do plan to decrank it to level it off later tonight. If the stock keys dont take it down to level, then Ill be forced to use the keys that came with the kit. Im looking forward to decranking the stock keys, as when I bought the truck it rode like butter.
IM happy with this kit, and happy I did not go lower than a 2/3. 2/3 is perfect for me. Ill snap some pics as soon as I can. Just wanted to compent on the ride quality.
Travieso
Boooooooost !
Los Skandeles, CA
i would honestly swap out the stock keys i notice a really vast improvement in overall ride quality when i did mine. Plus you have more room to play with, don't forget as soon as your done fitaling round with it..... redo the alignment
hoe
hoe
great advice bud. I did decrank the stock keys, and it brought it down alot, as I have a 2wd. Front is slightly lower than the back now. But I want to crank another turn back up or it may only take half a turn to level it with rear now. So far I am very impressed.
I would change the keys as soon as time prevails. But honestly I dont think it can get any smother than this. Rides better than stock. I got some pics of it today, so Ill uplooad those tonight. Now that I can see the roof, I have plans on removing the rack and molding up there now.
Dn69427
