kbexperience
- Joined
- Dec 16, 2014
- Posts
- 28
- Reaction score
- 3
Hello all,
2016 Escalade ESV
I’m upgrading my wheels and tires and before I do so I’m trying to figure out what is causing my tires to wear unevenly in the front. I’ve had an alignment done twice. By two different shops. None of the suspension parts are worn out. New shocks not too long ago. Both times the alignment showed to be in alignment with some slight adjustments made. yet the outside of my front tires are completely worn out in about 25,000 miles. Almost identical wear on both sides. The rear tires are perfectly fine. I realize I should’ve rotated them, but I’d like to get to the issue before I put new tires on it. I’ve read that this can be caused by toe. If it was too much camber, more than half a tire would be worn out. These are both done on Hunter machines by two different shops. Any insights?
2016 Escalade ESV
