zieglerj-pdm-specialist
Does a 2004 Yukon XL have an oxygen sensor before and after the catalytic Covertor???
Yes it should have a pre and post cat O2 sensor on each side unless long tubes, or custom exhaust, have been installed that delete one.
What if I want to put dual exhaust on it how would that work??
Are you wanting to run true duals off after the cats with 2 mufflers or change out the stock muffler for a 1 in 2 out? Either way you can still run cats and all the sensors, Just have an exhaust shop weld in flanges for the after cat set up.
